Crafts & Hobbies Logo
Tiffany Posted on Feb 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've just gotten into leather crafts and I need some ideas for some DIY projects. Recommendations please!
Be Bella
Level 2:
Scholar:
  • Expert 124 Answers
  • Posted on Feb 20, 2013
Be Bella
Expert
Level 2:
Scholar:
Answers
124
Questions
12
Helped
44082
Points
183
Here is a list of some ideas for leather crafts. Have fun!
http://papernstitchblog.com/2012/05/04/friday-diy-9-things-you-should-make-with-leather/
tip
How to dye leather
It may sound like a very complicated project, but dying leather actually isn’t that hard once you understand how to work with leather.
It’s important to understand the type of leather you are working with and the effect that you are hoping before.
Read on to find out some very helpful leather dying tips:
1: Find out what kind of leather you are working with. This doesn’t refer to the animal in came from but rather the treatments that the leather went through in the past. Ie has it been dyed? With or without a protective layer? Is it pigmented?
2: Choose your type of dye carefully and get advice from the shop where you buy it. Alcohol based dyes produce a stiffer leather finish whereas water based dyes are softer.
3. Choose a color dye but be aware that once it dries it is never the exact same color as the box. If you have a small sample ( a swatch) available, try it out first.
4. Take off the old dye before you apply any new dye. You can buy a leather deglazing product which takes off old dye.
5. Make sure your leather is wet before you start to dye it. Don’t soak it, just use a cloth to make it damp.
6. Now you can apply your leather dye follow the instructions on the packet.
7. Make sure you let the dye dry for several others. It may need manipulating a few times so that it doesn’t become stiff.
on Dec 25, 2013 • Crafts & Hobbies
Can anyone a good kit for the first time I try my hand at leather crafts?
This deluxe leather kit from tandy leather would be a good kit for you to start with: http://www.tandyleather.eu/en-eur/home/department/starter-sets/55510-00.aspx?countryid=1077
What is a good idea for my first leather crafts project?
As a beginner, a good idea for your first leather crafts project would be to make a bracelet. This is relatively easy to do. You can split the leather into strips and braid them or add beads for decoration. You can find many how-to videos online.
I'm doing a rubber stamping project. Should I buy a craft knife?
Yes, you should. craft knives are really useful in rubber stamping. A basic craft knife is all you need. You use the knife to carve the design you want.
1helpful
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
1helpful
2answers
When i start sewing the thread tangles and seizes up within 3-4 stitches. I've removed and cleaned the bobbin case a few times.
change the needle
make sure the thread has not come off of the thread take up lever
rethread the machine top & bobbin,, make sure to use every
thread guide
make sure to not over fill the bobbin,, make sure the bobbin is not
warped or damaged
My machine is doing stretch stitch on straight stitch position
sounds like a gear has worn or gotten damaged, a trip to the repair
shop would be a good idea
I have a Windows Hp 1000 Mini & The Screen does not turn on it remains black & blank. I've gotten the tip that I must reinstall the Operating System on it. But Does anyone have any Idea ho
Almost all of the HPs Mini laptop screen issues are related to the internal video card/motherboard. hopefully you still have the laptop under warranty.
www.linkedin/in/diaztech
twitter.com/diaztech
www.diaztech.com
I need a memory craft 3000 manual in English from the UK. Does anyone know where I can find one. Thank you.
There are a few sites, if you do searches through Google, where you can pay $8 USD or so to download the manual. You can also find the CD on eBay. I'm afraid I've done a lot of searches for a free download, but there just isn't one I've found. Maybe you could be the first person to download it to this sight for others, if you're feeling charitable.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
