I put it in my backpack for gym then when i came back the time was gone and the date. Only the temperature shows up and its fading. How can this be solved?
SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
SOURCE: my nixon watch shows fogging
The problem is that water or humidity is getting into your watch. You either need a new back gasket 9 probibly nicked when changing a battery, or your crown ( the little piece used to change the time) gasket is bad, or you have a crack in your crystal. Turn your crown as if to wind it , if it turns REALLY easy your crown gasket is bad, if not you need to open your watchback and insert a new gasket around the back cover. Make sure that it fits tight ( you probibly have to stretch it a little) and then reclose the watch. The only place I know you can get a seal is at a watch repair shop.
SOURCE: nixon 51-30 screw that hold the band onto the case
Not if they say they won't ship it to you.
Hope this helps,
Ken
www.yellowstonewatch.com
