HERITAGE II model HD2 HD. I don't want to open the bag if I need to return them :)
SOURCE: KIRBY HERITAGE II
Here are some Kirby phone numbers, they should be able to tell who does Kirby in your area. You could try calling a local repair shop to see if they can help.
US----------------(1)-800-437-7170
Europe------------(1)-800-547-9272
Africa------------(1)-800-203-222
SOURCE: I need to install a mini emptor on a Heritage II Kirby
I actually figured this out on my own. Just removed the rubber out seal between the bad and em-tor, then used a screw driver to gently pry the bag out of it's grove. The wire part of the hose actually unscrews from the em-tor. Reverse the process to install the new one. Gotta love Kirby engineering.
SOURCE: replace my fan on my kerby
I had to replace mine fan yesterday. I broke away some of the outer pieces and grabbed the fan around the center with some vise grips and put another vise grip on the shaft. ( You can also put a hard steel tool of some kind through the hole in the shaft) when facing the front from the attachment side the shaft unscrews when turning it clockwise.It comes apart right in front of the fan where the washer is.
SOURCE: I AM LOOKING FOR DIRT BAGS ON THE HERITAGE II PLUS
http://www.kirby.com/Portals/S_Africa/homecareproducts.html go to this website and they can help you find bags. Just call the number for South Africa.
SOURCE: Have a Kirby Heritage II
This repair guide should answer all of your questions...
http://reviews.ebay.com/HOW-TO-REPLACE-REPAIR-KIRBY-VACUUM-HERITAGE-CLOTH-BAG?ugid=10000000175632303
Hope it helps! :0)
