Home Logo
Posted on Feb 19, 2013
I have a Jacuzzi low flow toliet. Sometimes the water won't shut off after it is flushed
Sometimes toilet doesn't fill with water until sink is turned on.
Do you really think 'toilet' is spelled 'toliet'? You wrote this 4 times.
Replace the water inlet valve. It sounds like it is sticking and you also have very low water pressure. Call in a plumber and get the water pressure test with a gauge.
Jul 13, 2022 • Home
When flush my toliet the water level in bowl comeback low how do I fix or adjust.
Depends on the make and model of the fill valve in the tank. There is a hose that goes into a pipe that is in the center of the tank. That pipe is the over flow protection but it also fills the bowl.
Mar 26, 2018 • Home
Winterizing
I think you have covered it all. Just last flush !
My jacuzzi toilet doesnt fill with enought water in the bowl to remove waste from porcilin when flushing
Hi, W/D here.
Check the water level in the tank. The force to flush waste comes from there. Normally the fill line is cast into the back of the tank, but sometimes it is on the overflow tube. Raise the level if it is low.
Also, make sure that the tubing from the fill valve is connected to the over flow tube (the tall tube).
Best regards, --W/D--
I have a single flush toliet and I am getting a poor flush.Toliet is 2 years old and was mad in 2006
Adjust the float height to allow mor water into the tank before it shuts the valve
Jan 22, 2011 • Kohler Home
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
5helpful
I have a Jacuzzi Perfecta toilet (bought Aug. 21, 2008) at Lowe's. I have the sales ticket. The toilet works fine. The tank fills very slowly (2 minutes) before it shuts off. It also makes a whistling...
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
1helpful
I have an older toliet that flushes but not well. It flushes but does not get a strong whirlpool and ''flush through''. Sometimes after it is flushed it will have paper of some other small suprise still...
Soap or other buildup in the gooseneck of the drain portion. Try raising the water lvl in the back of the tank and add a float to the chain attached to the flap.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
