How to change the oil pump and line on a Husqvarna 455 Rancher
Ok, start by removing the side cover/chainbrake,the guide bar and chain, there should be just two 13mm nuts holding the side cover on, if you have tooless adjustment there will be a single flip up lever to remove the securing nut, you now need to remove the clutch, there are two slots cut into either side of the clutch centre, these slots are designed to take a screw driver ( preferably the combi tool that came with the saw ) you can then jar the clutch off against compression by striking the end of the screw driver with a suitable hammer, the clutch is just threaded onto the crank, left hand thread, so comes off clockwise, once removed you can pull the clutch drum and bearing off, remove the single 4mm allen screw from the silver bar protection plate and remove the plate, you will now see the oil pump, held with one allen headed screw, the delivery hose will just lift off, the pick up hose and filter will come out of the oil tank once the pump is removed.
