SOURCE: Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
SOURCE: My Sears coldspot side by side model #59562990
Water dispensers don't work like a faucet. When depressed a circuit is made electrically to the water valve in the bottom back of the machine. Water is, if working normally, either 100% on or 100% off.
If you ask for water, and the supply is normal, but fails to stop except for dribble, then the dual valve in the back of the machine is not sealing properly, and a new valve will have to be fitted.
SOURCE: How do I replace the
Hello, Ice makers
and water dispensers are convenient to have on your refrigerator, but
can also cause a lot of aggravation if they are not functioning
properly. If your water valves are not defective and you are still
experiencing water or ice delays, you may have a clog in your
refrigerator hose line.
Instructions and material needed to fix it up.
Good Luck and thanks for using fixya.
SOURCE: Kenmore side by side ref
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
SOURCE: The Refrigerator isn't cooling. The Freezer
Due to the blocked drain it sounds to me as if the vents in the ceiling of the refrig. has frozen over so no air can be circulated from the freezer into the refrig. section. This tip i wrote will show ya how to clear the drain and addation to clearing the drain the ice build up would need to be removed from the vents. Here is that tip, http://www1.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
