Net10 LG Optimus Logic Cell Phone Logo
linda widdowson Posted on Feb 18, 2013
I cannot remove icons from home screens - Net10 LG Optimus Logic Cell Phone
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 18, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
70
Points
U hold icon then drag to where it says remove at bottom of screen
Unock a zte google account lock
Add
From any Home screen, tap the All apps icon.
Tap Email .
If no accounts are configured:
Enter the username and password.
Tap Next .
Follow the on-screen instructions.
If other accounts are configured:
Tap the Menu icon.
Tap Settings .
Tap Add an account .
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Delete
Tap Settings .
Under Accounts , tap the account type that you want to remove (for example, Google).
Tap the name of the account you want to remove.
Tap the Menu icon.
Tap Remove account .
Tap Remove account to confirm.
if you not get any solution please go the :-https://support.t-mobile.com/docs/DOC-27449 and ask your query
Note:-Need the ZTE network unlock code just get in one click only
Official Zte IMEI Permanent Unlock Important Select the Current Network...
https://www.unlockninja.com/unlock-zte+phone
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Add
Tap Email .
Tap Next .
Tap the Menu icon.
Tap Settings .
Delete
Tap Settings .
Tap the Menu icon.
How to remove an icon from home screen
On most Android tablets, you simply press and hold the icon until the screen changes modes (to arrange). Then you should see an option to delete/remove at the top of the screen. Just drag the icon to the top of the screen and it should leave the home screen.
I have multiple icons on my android and I don't know how to remove them
Removal could vary depending on the phone you are using and the version of android you have, and which screen the icons are on.
If the icons have been added to the home screen, on my S4 just press and hold the icon that you want to remove (just a couple of seconds), then drag the icon to the bin at the top of the screen.
If you want to prevent icons being added to the home screen when you install new apps, goto the google play store on your phone, and click on 'Play Store' at the top of the screen. Then goto 'Settings' and untick 'Add icon to Home screen'. Any new installs will be in you applications folder but will not be added to the home screen.
Jun 08, 2014 • Cell Phones
1helpful
I have a Apple IPad 2. I want to remove a home screen Icon, how do I do this?
press and hold down the icon until you see it shaking and an x next to it then press the x and delete.
3helpful
Icons on the home page
Tap the white-on-blue up-arrow near the lower-left corer of the screen, then drag the unwanted icons to the icon bar at the bottom of the screen. When done, tap the white-on-blue down-arrow at the upper-left corner.
Bear in mind that not all icons can be removed from the home screen.
A icon just appeared on my screen that says phones
You may have accidently put an app icon to home scree. You can delete it by press and holding the icon. A trash icon will appear at the buttom of the screen. Drag the icon to the rash icon and you are done.
It wont delete anything. It will just remove the icon from home screen.
Also, to add any other icon on the home screen, go to menu, press and hold the desired app icon and it will be on the home screen.
99helpful
3answers
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
IM icon on home screen
To remove these, press and hold the icon until your phone twitches (or vibrates briefly) and then drag them towards the menu popup (at the bottom of the screen). You will see the pop-up menu button becomes a trashcan. When the icon gets close to the trash it turns red. Just plop it onto the trashcan and it's gone.
Jan 02, 2009 • HTC G1
Top Net10 Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Net10 Cell Phone Expert? Answer questions, earn points and help others
