Craftsman Garage Door Opener 1/2 HP Chain Drive Logo
Posted on Feb 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Garage door opener light flashing
Light flashing door wont close
Anonymous
Level 2:
Champion:
New Friend:
  • Expert 217 Answers
  • Posted on Feb 27, 2013
Anonymous
Expert
Level 2:
Champion:
New Friend:
Answers
217
Questions
15
Helped
108157
Points
371
Check the safety reversing sensor, page 23 if you still have the owners manual. if not, reply to this thread
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Garage door opener does not close with remote. It will only close when you press the garage button
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flashing ever so slightly. Tweak the sensors a little. If you cannot get both lights to come on you have bad sensors. If this is not your symptom post back.
4helpful
My garage door opens fine, just wont close with remotes. Lights just flash. I have to use the opener in garage and keep the button pressed in till the door is fully closed or it will reverse.
Clean both safety sensors lens located at the bottom of the garage door frame. Make sure both sensors led lights are lit. If not they are out of alignment and you will have to loosen the wing nut on the sensor that is lit and move it, trying to get the other sensor to light.
I have liftmaster professional garage door opener. it opens ok but does not close with remote and light keeps flashing on garage door opener. I checked both sensors and seems like the sending sensor light...
If your sensors are not pointed at one another the light on one of them will go out. Tweak them a bit. If you cannot get the light to come on then your sensors are bad.
Keypad opens the garage but wont close it
If when you try to close the door the main light flashes 10 times you have a door sensor problem. Make sure they are pointed at one another.
1helpful
The door opens bot wont close i dont have a wireing chart
If when you try to close the door the main light flashes 10 times and the door reverses to the open position you have a sensor problem. Make sure the small light on each sensor is on and not flickering. Tweak them a bit to see if you can get the lights on. If not you have a sensor that has failed.
Myt 1/2 hp craftsmand door opener clicks and light
If the main light flashes 10 times when the door reverses it is a door sensor problem. Each sensor has a small light that needs to be lit and not flickering for them to work. They must be pointed at one another for the lights to be on. Tweak them a bit and see if the lights come on. If not you likely have a bad sensor.
Top Craftsman Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
