Front right heating element can not be controlled. It's always on high even when set at low.
You will need to replace the surface element switch. Here is the part to order. Below is a video to show you how to replace the switch.
Testimonial: "Thanks so much! The folks at GE wanted to send a tech out for $79 service call. They also said that the whole top probably needed to be replaced. You saved me a ton of money!"
SOURCE: GE Spectra Profile - dual burner only has one temperature - HIGH!
you need a new switch that is in the control panel
SOURCE: element replacement
Sorry, but that's a bad one. If you have a JBP78 as you posted under, the broil heat relay contacts arched and welded closed. = replace electronic range control. If you do not have that model, you may have a separate bake / broil switch, which is where that problem occurred and then that would be able to be replaced.
SOURCE: While cooking on the right front burner, it began
if the burner works on high ( burner is ok ) replace the sw on back panel it's the problem / this is not a uncommon problem .. ****
Testimonial: "Thanks for the help. After I posted my question, I spoke to the local Sears parts counter, and they share your opinion."
SOURCE: GE Elec Range - front left burner will not turn on
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
SOURCE: GE Electric range coil burner does not work on low
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at http://appliancehelponline.com/infiniteswitchvideo.html that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
