Kenmore 24" Self-Clean Wall Oven 3055 Logo
john vana Posted on Feb 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven won't heat up - Kenmore 24" Self-Clean Wall Oven 3055
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Feb 18, 2013
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628610
Points
28464
What is the complete model number of your unit?
Help it lights up but no heat.
Dont use it! You need to pull the cooktop and see what is wrong. There is a chance that the circuit for the surface light is the only standing circuit left because the heating element is bad or loose
May 20, 2013 • Ovens
Oven won't heat
major electrical problem. call a repair man asap!
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Oven won't heat to temperature
Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
2helpful
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
1helpful
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
1helpful
My oven won't reach the appropriate temperature
It is a problem with neither of the two it is the sensor reads the oven temp and shuts off the heating element when it is reached, it is called the thermal probe or thermostat.
My oven stopped heating, and the range element won't turn red when you turn it on but it does have some heat coming from it. What's wrong with it?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 [
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
heatman101
Jul 25, 2011 • Ovens
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
