Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look (((•))) Make sure its pressed on. Usually a wifi enabled phone, computer, or whatever device, will recognize if there is wifi access near you. If not you may need to turn on the wifi on those devices. Usually those setting can be found in menus like Network Settings. Once it recognizes the network you will need the password if it is required. Just enter that in and you are set. Where you enter the password is usually in the same menu in which you turned on your wifi enabled device. if still no connection Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. Click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
Are you pressing the correct keyboard combination? You need to press the "Fn" key (next to the Windows Key at lower LH side), and, holding it down, press the "F3" key. Doing this once turns the wifi ON, again will turn it OFF.
make sure the far right wifi light is blinking (next to your battery light).. if it is not push and hold your blue fn button witch is by the control on the bottom left, and at the same time press the f3 button.. that turns the wifi on..
Maybe your wifi is turned off. Try Pressing FN + F3, press it only once because pressing it again will turn off the wifi again.
Or maybe your wifi driver is not yet installed. Here try using this software.
LINK
Just download and install the link above.
After installing just scan your computer and download your wireless lan driver.
Hope it helps goodluck.
Make sure that driver is installed properly. If it is, check for wifi switch. Make sure it is turned on. In some laptops do not have switches, they use the functions keys to turn them on. Use Fn+F2 or Fn+F3. Also, make sure that you just have one wireless utility activated in the computer. It is more advised that you use the Windows Wireless utility which is more compatible with most types of routers.
Lastly, check your wireless card and the wireless router if they are wireless a,b,g or n. If the router is wireless n, your card should also be wireless n. If your card is just b or g, it would not work.
Usually, if there is no HARD SWITCH for wifi, there is an equivalent keyboard key combination to turn wifi radio receiver ON. Look at your laptop's Function Keys: F1, F2, ... F12. Among them there is an icon for WIFI, something that looks like an antenna with wave signals. Now press and hold the FN key and press that function key with the wifi icon. Example, if the wifi icon appears at F10, then press FN + F10 to turn your wifi ON or OFF.
