SOURCE: he220a honeywell humidifier water actuator valve broke
The screw does turn and will open the valve, take the hex nut off and turn the screw to see if water leaks between the valve portion and the hexnut housing. They used that same valve on many models, including the newer models. Make sure you are getting water to the valve.
Hello I had the same pbm, I could not find it anywhere other than ordering it through the net. You will find info & picture at http://images.google.com/images?hl=en&q=Solenoid++valve&um=1&ie=UTF-8&sa=X&oi=image_result_group&resnum=4&ct=title
For a humidifier issue, you do not need the same exact original part, it is best of course but another brand will work.
I tried to loosen the standard screw that seats inside the nut, no luck either way. Could that mean the valve is stuck open causing continuous water thru the valve?
