LG Tromm Front Load Washer And Dryer Set Logo
Williamson Posted on Feb 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Are they stackable? - LG Tromm Front Load Washer And Dryer Set
Anonymous
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on Feb 17, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
104
Questions
0
Helped
45954
Points
341
Yes they are but you will need to get the kit , it is just a bar set with double sided tape
1helpful
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
2answers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
3helpful
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
2helpful
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
36helpful
4answers
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
How to test/change heating element in stackable dyer
pop me and email at [email protected] and ref stackable drier oh dont forget my 4 boxes
May 25, 2008 • Dryers
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
