Question about D-Link DIR-300 Wireless Router
Hi. My device is transmitting internet to some devices (phones) but not others. How can I solve this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 29 Answers
Try deleting the wireless associations on the devices which have the problems, and then re-connect the device to the router. This should solve your problem.
Posted on Oct 30, 2013
When I connect my qmobile e900 to my pc with usb cable it does not show any option such as "Mass Storage" etc. it just says usb charger connected. How can I solve this problem?
brother try connecting the cable to some other port and if its still the same trying changing your data cable....i think the rx tx lines are destroyed which transmit data from ur device to computer and from computer to your device
Jun 18, 2011 | Cell Phones
Ethernet light blinks continuously on my bigpond wireless. Does that mean there is a problem?
A constant blinking Ethernet activity light indicates that the computer is transmitting and/or receiving information from the internet or other network devices. It's nothing to worry about. The light may be constant only when we are setting up the modem.
Regards,
Shrey
Jun 01, 2011 | 2wire (1000-000057-000) Modem
When i call someone i can hear them they cannot hear me
I will start to search for the culprit (SIM or phone).
Try to change the SIM card in your phone. Just take out your SIM and insert another one, have another one borrowed.
If the problem is gone than probably it is the SIM (dirty contacts, chip malfunctioning, bad network access). Call your mobile company and ask for a replacement.
If the other SIM has the same problem then it is probably the phone. Try to turn off the device or, better, try to apply a soft reset.
If the reset does not solve the problem contact device assistance and explain the defect and the test you have already run.
If you are using a handfree set try another one.
May 24, 2011 | Cell Phones
I want connect a internet to my mobile by wifi the mobile asking the password
Hi. There's a security key to the wifi were you are connecting. You need to ask the owner of the wifi what's the security key. You need to input it before you can connect to the wifi
May 06, 2011 | Samsung Star GT-S5233 Cell Phone
I need usb driver in linux for my mobile samsung sgh x820
hi...
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
connect to mobile devices by IR, bluetooth, USB Cable
  1. Send and receive files between computer and device
  2. Access Internet from Device by Dial Up Networking
  3. Browse files on Mobile device
  4. Mount the mobile device on a user specified mount point or communication port.
    usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  1. ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
  2. fully automated connection setup. No manual input is needed except to specify connection name.
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Dec 12, 2010 | Samsung SGH-X820 Phone
I installed a new Zonet 1605 wireless adapter so i could pick up the wireless internet from my niegbor it does not work why?
You are not able to pick up your neighbor's network can be due to various reasons.
1) Check if the adapter has been installed properly. Check the device status in the device manager. It should say "This device is working properly"
2) The distance might be too much for you to receive the wireless signals.
3) Might be having any other wireless devices like a cordless phone near your computer which may cause interference.
4) Your neighbor's wireless router might be transmitting signals in 802.11a or 802.11n standards which is not compatible with Zonet 1605 adapter.
5) Your neighbor would have password protected his wireless network to avoid illegal use of his internet. These days there is more importance given for wireless security.
Thanks and regards,
Arvind S Iyer
Sep 26, 2010 | Zonet (zew1600z) 802.11g/b Wireless...
My IPod Touch has a white screen. It won't do anything. I think it is frozen or something. What should I do?
the problem can be solved.Did you download any data from the internet or did you transfer data from any other device?.
If yes , that means in the process of transferring data into the i pod or from any other device to the i pod, some data might have been affected and the memory might have been corrupted by virus.
You need to flash the phone to so that the phone can restore back the lost memory of the phone.
Good luck and have a nice day.
Mar 16, 2010 | Apple iPod touch
I am trying to connect via bluetooth my phone ericsson w880i with my nokia n810 internet tablet but it keeps on saying connection failed could you explain how i could make this work.
Make sure both have bluetooth enabled, I suspect that the n810 may require a nokia phone for the phone features. The device didn't register my qtek phone at all.
Mar 10, 2009 | Cell Phones
My wireless internet isn't working on my Dell Inspiron 6000.
try launching An Internet Explorer, Or web-browser Page.
Also You could look in the device manager, for any problem-devices. Then check that you are getting A receive as well as Transmit signal. ( bytes sent/received ) Check settings In Internet Connectivity.
Mike @ compurepair.
Jan 21, 2009 | Dell Inspiron 6000 Notebook
D-Link DIR-300 Wireless Router Logo
35 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
