Computers & Internet Logo
Anonymous Posted on Feb 17, 2013
Dell dcsm power button broken
Dell DCSM will not power up, but amber light glows on motherboard when power cord is plugged in
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Feb 20, 2013
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390676
Points
6614
Replace the power supply in the computer.
5 Related Answers
Anonymous
  • 326 Answers
  • Posted on Aug 11, 2008
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Anonymous
  • 10 Answers
  • Posted on Aug 20, 2008
SOURCE: I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Anonymous
  • Posted on Nov 01, 2008
SOURCE: Dell GX280 no display
I solved this on a Dell GX280 by removing the CPU and then reseating it in the socket. Also cleaned cpu and heatsink and applied new thermal compound.
Anonymous
  • Posted on Feb 20, 2009
SOURCE: Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
ajx13
Arjun Aukta
  • 110 Answers
  • Posted on Aug 11, 2009
SOURCE: Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
My 2009 Lincoln MKZ is having issues with the heated/ventilated seats. Lights come on, heat partially works. Ventilated feature doesn't work, but I can hear fans. How do I fix?
Heated Cooled Seat Control Module . B2486- climate control seat module voltage out of range.
Did you test voltage out of range with DVOM - digital volt ohmmeter ?
B2486 Climate Control Seat Module Voltage Out of Range On-Demand and Continuous REFER to Section 414-00 to diagnose the charging system concern.
B103C Thermoelectric Driver Open Load On-Demand and Continuous Go To Pinpoint Test T .
Pinpoint Test T: DTC B103C - Thermoelectric Driver Open Load
Refer to Wiring Diagrams Cell 119 , Climate Controlled Seats for schematic and connector information.
Normal Operation Both the driver and front passenger climate controlled seats are independently controlled electronically by the dual climate controlled seat module (DCSM) mounted to the bottom of the passenger seat cushion. The climate controlled seat system only operates with the engine running, however, if using a scan tool to command the DCSM, diagnostic testing can be carried out with the ignition switch key ON engine OFF (KOEO). The system receives power from battery junction box (BJB) fuse 12 (30A) feeding battery voltage on circuit SBB12 (GN/RD) into DCSM C3305a pin F. The system also receives power from BJB fuse 11 (30A) feeding battery voltage on circuit SBB11 (BU/RD) into DCSM C3305a pin E. If power is disconnected from either pin E or F of DCSM C3305a with the power connection remaining on the other circuit, both seats will remain operational because the power feed circuits are connected internally in the DCSM. However, if a fault occurs setting a DTC specific to either climate controlled seat, only the affected seat will be disabled by the module and the other will remain operational.
Each driver and front passenger seat cushion is equipped with a thermo-electric device (TED) assembly that includes a seat blower (fan motor, serviced as an assembly with the TED). Similarly, each driver and front passenger seat backrest is also equipped with its own TED assembly with blower. Cabin air is drawn through the blower and distributed to each of the TED modules located in the seat cushion and backrest. The TEDs then heat or cool the air. The air is then directed into the foam pad and manifold where it is distributed along the surface of the cushion and backrest of the seat. Once the system is activated, the DCSM uses a set of flexible algorithms to control the heating/cooling modes and the blower speed dependant on the EATC seat switch settings.
Possible Causes A TED driver open load fault can be caused by:
  • wiring, terminals or connectors.
  • a faulted TED assembly.
  • a faulted DCSM.
Just bought a 2006 Lincoln Zephyr. The heated and cooled seats do not work. Every other button and function on the climate control works properly besides the heated and cooled seats, both driver and...
Tried resetting fuse's ????? how do you reset a fuse ?
The climate control seat system is able to heat and cool the front seats. Each climate controlled seat is operated by push-buttons on the EATC module located on the instrument panel. Each front seat temperature is then monitored and controlled by the dual climate control seat module (DCSM) located on the passenger front seat track.
The climate controlled seat system contains the following components:
  • EATC module
  • DCSM
  • Thermo-electric device (TED) and blower assembly within each front seat cushion and backrest
  • Air filter (attached to each TED and blower assembly)
  • Cushion and backrest manifolds
  • Cushion and backrest foam pads
  • Cushion and backrest trim covers
  • YOUR best bet , take it to a qualified repair shop . Unless you have factory service repair info. an a professional scan tool , This heated an cooling seat system can set DTC'S - diagnostic trouble codes in the heated seat module .
Climate Controlled Seat System
NOTE: When installing a new dual climate control seat module (DCSM), it is necessary to carry out programmable module installation (PMI). For additional information, refer to Section 418-01 .
Both the driver and front passenger climate controlled seats are independently controlled electronically by the DCSM mounted to the bottom of the passenger seat cushion. The climate controlled seat system only operates with the engine running, however, if using a diagnostic tool to command the DCSM, diagnostic testing can be carried out with the ignition switch key ON engine OFF (KOEO). The system receives power from battery junction box (BJB) fuse 12 (30A) feeding battery voltage on circuit SBB12 (GN/RD) into DCSM C3305a pin F. The system also receives power from BJB fuse 11 (30A) feeding battery voltage on circuit SBB11 (BU/RD) into DCSM C3305a pin E.
If only one of the BJB fuses 11 or 12 open, both seats will remain operational because the power feed circuits are internally connected in the DCSM.
Both climate controlled seats operate independently. If a fault occurs setting a DTC specific to either climate controlled seat, only the affected seat will be disabled by the module and the other will remain operational.
The 4 switches (identified with seat icons) on the dual-zone electronic automatic temperature control (EATC) module activate each seat system setting and illuminate LEDs above each switch to indicate the operating mode, 3 LEDs for HIGH, 2 LEDs for MED or 1 LED for LOW. The push-buttons with the blue seat icon operate the seat cooling mode and the push-buttons with the red seat icon operate the seat heating mode. The climate controlled seat system is not equipped with auto-mode.
The TED uses a ''Peltier'' circuit of P-type and N-type semiconductors connected in series using copper electrical conductors. The semiconductors are sandwiched between 2 copper heat exchangers. When current is applied to the TED, one side releases energy as heat, while the opposite side absorbs energy and gets cold. By reversing the current flow, the hot and cold sides reverse.
NOTE: Avoid applying power directly to a TED for testing its operation. Doing so may cause damage to the TED or shorten its usable life.
The temperature differences between the individual heated and cooled settings is minimal. For example, it is difficult to distinguish between LOW COOL and MEDIUM COOL settings. Measuring seat temperature at different settings is possible by monitoring the DCSM PIDs using the diagnostic tool.
The EATC module communicates climate controlled seat commands to the DCSM using the medium speed controller area network (MS-CAN) communication bus. The MS-CAN bus is connected to the data link connector (DLC) for diagnostic use. No direct connection exists between the DCSM and EATC for the climate controlled seat switches. The climate controlled seats can be commanded using the diagnostic tool to verify both module communication on the MS-CAN bus and operation of the DCSM. This method may be useful for isolating a control switch concern. It should also be noted that because CAN bus communication is more robust and reliable than other methods, it may be possible to have limited module communication with one of the CAN bus circuits disconnected or shorted to ground. Refer to Section 418-00 for additional information concerning CAN bus communication.
Dell DCSM will not power up but amber light glows on motherboard when power cord is connected
Does the CPU fan run or the PSU fan? if not then you should take a careful look at the capacitors around the CPU socket. They should all be the same shape and have either a flat top or a very small bowl shape. If you find any that differ you will need to buy a new board or replace the blown capacitor/s.
Where do i find dell dcsm mother board model number
Go to http://support.dell.com . Click "Support a product". Enter your service tag # which is found on a sticker on your case. Click "system configuration". Your motherboard number should be listed there.
1helpful
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
3answers
Only amber light is on when start...no green lights...
its a power problem. Your power supply is not giving enough power
2helpful
Computer locking at startup
If the LED is glowing Amber then there is definitely something wrong with the hardware. Open up the system and check to make sure that all cables are plugged into the motherboard securely. If they are, you have faulty hardware somewhere. I would take it into a repair shop and see if they can locate the fault.
Please rate,
Thanks!
7helpful
3answers
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
2helpful
2answers
Yello power light, dell
1st remove all PCI cards, see if anything changes.  If no change\:
If the power LED is solid AMBER, replace the motherboard
If Flashing AMber, replace the power supply
Grand Canyon Tech
Grand Canyon Tech
