Loose connection to the senser wiring or light or light or a bad senser itself. Bypass sencer and if the light then stays on, the senser is bad and wil need to be replaced..
great question. this kind of issue is generally a problematic lamp controller. Lamp controllers get "used to" the current over time. So if you have a certain milli amperage flowing across the lamp controller for X years, eventually the lamp controller gets used to that current
The below article is very good at describing how a lamp controller works:
The trouble you are describing involves YOUR control module INSIDE your fan body... I had a SIMILAR TROUBLE on a CASA BLANCA... had to replace the CONTROL MODULE myself... but for the 13 foot ceiling... and needing to ALSO upgrade the WALL SWITCH (Intelli Touch W32 Wall Control) to match... It was an EASY JOB.
Remember to ground out your hands before touching delicate electronic equipment (or an anti static wrist strap)...!!
Also remember... the REAL PROFESSIONALS always remove power (when possible).
Be SAFE.
To VERIFY, Technical Assistance... and get PARTS
Check out the links below or call:
Fan Man Lighting
15465 Cedar Ave S
Apple Valley MN 55124
(952) 898-2754 local
(866) 600-FANS (3267) toll free
Hours of Operation (Central Time)
Monday - Thursday 10:00 - 7:00 Friday 10:00 to 5:00 Saturday 10:00 to 5:00 Sunday 12:00 to 5:00
The globe getting too hot is common with discharge lights but have standard lights. What type of circuit protection do you have as normal overload trip the breaker. I would suggest experimenting with one globe in to see if the problem persists. If it stays on you have to go down to 25w globes - which would still be a touch high at 75w but better than 120w. This could be too dark for you though so an additional wiring solution might be needed
locate service manul / wiring diagram comees with all usually convenietly located taped to back inside pannel. shut off breaker , or slide out an unplug, read, manul if present plug back in fallow the set up steps,an trouble shoting. press,bake, set temp,and press start press timer,set timer ,and,press start again.should do it,.if not check for loose wire on oven senser.possible touch pad replacement. worst case. good luck ,.
There is a small relay in the ceiling fan causing this noise, try turning off all power to the ceiling fan and allow it to set for a couple of minutes. Turn it back on and see if it goes away. If it does great. if not, it may not be worth the repair cost but it can be fix by an appliance tech.
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to.
- P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Usually there is a senser on your disk pad with the wire connect to the light, when the pad is too low, the senser touch the disk rotor and grounded, the light is on.
If you do not use the original disk pad from the dealer, the senser is not build in, when you put the disk pad, must put right and connect the wire right, otherwise it will go on. No harm at all. just one pad didn't right, the light will on.
I don’t know what pad you put in.
About the fuel light;
How long the light going on or just a little while?
