Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
The TV >>receives<< Video and Audio from the Samsung. Page 19.
The unidentified TV with its unknown audio capabilites has a manual somewhere, too.
How many TV's are actual audio sources?
If the TV is actually a root source of programming (say, through its own antenna) you can run cables from it to the Samsung as you would any other audio source. If the audio really comes fro ma Cable Box THAT is where the best TV-related audio will come from.
the bit rate of audio is high thats why audio not support while playing video, use normal bit rate video or audio , u can convert your fav video and audio through your pc
Sorry, I have to say this! If you can't find the power supply... You have no business tinkering around inside the set. You can cause more damage! Or be injured!!
I have one of these. It sounds like your projection light bulb has burned out & it needs to be replaced. Last time I checked (2 years ago), they were about $200. They are not hard to change if you are handy. Follow the directions, do NOT touch the bulb with your bare hands, use gloves or the oil from your hand will cause it to burn out prematurely. If you are not handy, call for a repair person.
Since you can hear the station it is tuned to, it doesn't sound like there is a problem with the tuner.
You need to make sure that the inputs on the TV support the resolution that your DVD player is outputing - Component inputs 2 & 3 do not support 420i...
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
