Cellphone volume decrease due to following reasons you can resolve if you go through it.
1.If you have recently changed any Cellphone Panel, you have to check whether Ear Volume holes are perfect or not..for new panels it wont have Holes proper make it clear.
2.Remove the Dust between Ear Speaker and Panel.
3.If you wan to Increase Ringer Volume check the Dust and Volume out vent gap is proper or not.
We cant increase default volume with any codes...
SOURCE: how to increase volume in
Yes there are.but those things made the output sound quality to decrease.Best way to keep it as it is
SOURCE: i need to increase the volume for my nokia 3110c with codes
i need the setting of pocket internet for nokia 3110c
SOURCE: Code to increase my ringtone volume on Nokia 3110c
*3370# / #3370# Activate / Deactivate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
*#4720# / *#4720# Activate / Deactivate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
SOURCE: are there any codes to increase volume of nokia
As far as I know, there is no such code to increase you phone volume. Codes are only use to Unlock Your Phone and to do a Masrter Reset. Codes can be generated via your phone unique IMEI code.
SOURCE: how to increase my cell
Hi anand8055,
While facing your Cellphone there is a button of upper right side of you cellphone. This buttons is Volume up and Volume down. Hope this helps
i want to increase the volume of nokia 3110c through codes
