I try to add a device through my Asus. It finds the google tv but it says that it is not windows certified. Is there another way to connect these two devices.
SOURCE: adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
SOURCE: Wireless network adapter - Vista
I know this is over a year, but have you tried checking the bios setting? It may be that the bios has an option to disable the integrated wlan.
SOURCE: can't find bluetooth connection on laptop to connect 2cell phone
This computer has no bluetooth, check here.
You will need to buy an external bluetoothe adapter like this ones:
100m Wireless USB 2.4ghz Bluetooth ...
100M Wireless USB 2.4GHz Bluetooth ...
BLUETOOTH 1.2/2.0 USB 2.0 100M
IOGEAR GBU311X Bluetooth v1.2 USB ...
IOGear gbu301
Motorola OEM Bluetooth Adapter PC850. ...
SOURCE: ASUS A6 Series Entertainment Notebook VGA, Modem & Audio Devices
check this link and find your model and operating system. download.
http://support.asus.com/download/download.aspx?SLanguage=en-us
