Need manual for Pioneer DEH 6350 SD car stereo
You may download a copy of the manual here.
SOURCE: WIRING FOR PIONEER DEH 16 CAR STEREO
you need to find the Pioneer website, or something similer... google the DEH 1600 diagram. really you just need something that tells what the different wires represent by color. then find a wiring diagram for the make and model of your ride that cooresponds to your stereo set up... then just match up the wires and there you go... personally i suggest haveing one of the boys at Best buy throw a harness... it costs like 15 bucks or something. plus you know it will be done right, and you can take it back if its not and have it fixed... bottom line they will be liable for any problems... hope this helps.
SOURCE: WIRING INSTRUCTIONS
Red=Positive 12v(switched)
Black=Negative ground
Yellow=Constant Power(Battery or fuse box W/ Constant power)
Grey=Right front+
Grey/Black=Right front-
Purple=Right rear+
Purple/Black=Right rear-
Green=Left rear+
Green/Black=Left rear-
White=Left front+
White/Black=Left front-
Blue=Amp turn on
Blue/White=Power antenna
Orange/White=Dimmer
SOURCE: PIONEER DEH P 5450
turn it off press the time display button located in top left corner then time will display,then pres and hold top right corner button until 12:00 flashes first the 12 will use your channel buttons on right side to scroll up the the time then when you get the correct time set press the clock display button again in top left corner of face plate!merry christmas!!!
SOURCE: Need Wiring Diagram for a Pioneer MOSFET 50 Wx4
Found the manual on Crutchfield's site
The wiring diagram is on Page 25
SOURCE: pioneer ECQ MOSFET 50wx4 DEH-6500 Need manual
here hopes this helps ya click on the onwers manual half way down.
DEH-6500
