Question about LG WM-0532HW Front Load Washer
LF Front Loader WM 1355h. Works fine except when I do a "tub clean" cycle it always stops and give the OE error code. There is water remaining in the tube. The coin and lint trap is clear. I have to r
    New Friend:
  • 104 Answers
Do you see a lot of sudds? Do you put anything in for the clean ? Operator error LG washers are great but can be touchy
Posted on Feb 16, 2013
  • 2 more comments
  • app_3rp93422
    app_3rp93422 Feb 16, 2013
    No there are no suds and I follow the user manual to place some bleach in the softener dispenser but no clothes or detergent. I then turn on the washer, press "tub clean" and start. It goes through the cycle almost to the end but then stops with the "OE" error and water remains in the tub. I stop the machine and restart a "spin drain" cycle and it empties and shuts off. All other cycles work fine. It's just the "tub clean " cycle.
  • nate nixon
    nate nixon Feb 16, 2013
    you may have a lot of buildup in the tub . yout can try using white distilled vinigar instead of bleach on a heavy cycle with hot water
  • nate nixon
    aand cut way back on your soap 2 tbs per load . it will clean your clothes just fine
  • app_3rp93422
    app_3rp93422 Feb 17, 2013
    Yes I only ever use HE detergent and only 2 tblspoons but I will try your suggestion of just running white vinegar through an empty hot wash cycle. Not sure why the potential "build up" problem, OE error would only happen during tub clean sysle. Thank you for your responses!
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
Posted on Jun 24, 2009
Anonymous
SOURCE: LG WG3431HW OE Error: Rattling & Not Draining.
water will not drain says oe
Posted on Aug 08, 2009
L have a samsung front loader and the water wont stop unless l turn power off at the socket! it shows a oe code
Hi
Thanks for using FixYa. OE is overflow error which occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected. If the issue remains then clean the drain pump located at the front lower panel. Please revert back for further assistance.
Thanks
Rylee
Dec 23, 2011 | Samsung Washing Machines
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
The washer does not go into the spin cycle
if it gives you an oe code then your filter is blocked or bad water pump clean out filter at front of washer (bottom left corner)
May 06, 2010 | LG WM-2277HW Front Load Washer
My lg front load washer stops and give me an error message OE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2009 | LG WM-2277HW Front Load Washer
For LG WM2233HW, Error Code OE. Already check drain hose and filter, all clean. Try different cycles, TUB CLEAN, SPEED WASH. Same error code. No drain.
Jun 19, 2009 | LG WM-2277HW Front Load Washer
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Water will not drain from tub.
Clean out the trap from the bottom, something is jamming the drain motor
Dec 22, 2008 | LG WM-2277HW Front Load Washer
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
My lg intellowasher wd1290 error code OE
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Sep 21, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
303 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
