The numbers and symbols around the dials on my Diplomat ADP3640 oven have rubbed off. I have looked in the manual, but it just tells me what the symbols mean, not where they are located around the dials, and I can't find a picture anywhere. Does anyone have the oven with numbers still left on and could tell me where they are, or have a clear picture/diagram of the dials? Especially the temperature dial, as I know where the functions I use most are located, just no idea where any temperatures are! Thanks
You can buy new decals for this model from Ovenlettering"
Hi Natalie, were you able to find a solution for this?
All the images are scratched on mine so I don't even know which knob position is for what...
thanks!
Hi, were these ever found out? I have the same issue.
Thanks
Possible vendor in England to call that may be able to assist, but manual no longer appears to be available. https://www.inter-spares.co.uk/diplomat/... Search of internet suggests possibly 2009 or earlier manufacture.
SOURCE: No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
SOURCE: SMEG SA708X oven's symbols have rubbed off, wioul
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
