Even though the SD card is installed the camera saves pictures to internal memory.
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: transfer pictures from the internal memory to the memory card
http://www.kodak.com/global/en/service/publications/urg00402toc.jhtml?pq-path=6863
There is a listing to call their tech support.
I cannot find a way other than usb connector.
Here is a link to the manual as well...
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00402/Z730_GLB_en.pdf
SOURCE: Can photos be transferred from internal memory to sd card
im not sure on yours but on mine there is a option for copying a picture under the menu just go to the pic you want on the externa. memory and go to your menu find copy picture and then it will copy to it
SOURCE: Internal memory is full
Check the settings for the default storage.
On the camera press "Menu".
In the menu go to the camera settings symbol (camera and wrench).
Go to the "image storage". Is "internal" or "auto" selected?
Is internal selected copy the files to the memory card.
Leave the menu. Press "preview". You'll see only pic's from the internal memory.
Press "Menu" ... "Copy" and choose all.
After that go back to "image storage" and choose "Auto" and -if necessary- delete the files from the internal memory (remove the card before!)
SOURCE: Took pictures on camera without inserting card, no cord
Yes, there is.
Insert the card into the camera. Make sure the storage location is set to internal memory.
Press the Review button, then press the Menu button. Press up/down to highlight Copy, then press OK. Press up/down to highlight an option, then press OK.
Note: this process is actually a copy, not a move. The originals will still be in internal memory. After you transfer the pics to your computer, you can then delete them normally.
To change the storage location, press the Menu button. Press up/down to highlight Image Storage, then press OK. Select Internal Memory and press OK.
Testimonial: "Exactly what i needed to know. Thanks!"
