Had power outage hasn't came on since no lights at all , checked fuses there ok nothing else in the house was effected
SOURCE: WD-62525 dead after power outage...no lights no
Alot of times on these Mitsubishi tv, there are about 4 boards that have cappacitors that blow. If your lucky, it may just be the capacitors on the power board.
SOURCE: After power outage timer light is flashing and tv
We had a similar problem with our Toshiba. It turned out to be that the mercury bulb was toast. Open the owner's manual & look in the Troubleshooting section. The blinking for us was indicitive of a bad bulb. Sure enough, we took it out & it was obviously cooked. Don't buy from a local store, buy it online. You'll save between $30-100 & our "cheaper" bulb has been working for 2 years. Hope this helps!
SOURCE: after a power outage the
The power outage may have fried your power inverter or possibly the flyback. You can use a voltmeter and test the power inverter to see if there is power going to the main control board from the inverter.
SOURCE: Yesterday we had a power
Thats caused by weak capacitors on the DM board. They drain when the power is lost then they cant recharge after power is restired. You can get the dm repair kit for your model at www.tvrepairworld.com it contains the repair instructions and the upgraded caps plus other service info on the cd
SOURCE: Green light on front of
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
