SOURCE: unresponsive htc tytyn touch screen
i had the same problem, it turned out to be dust caught just under the plastic at the edge of the screen, a finger nail got it out or you could be fery careful and use a sharp flat knife. hope that helps,
SOURCE: trying to move photos from internal storage to computer
Do you use your phone to browse the internet? if so, go to internet explorer -> options -> memory. and let it delete all temporary internet files. That should free a lot of internal storage. Turning your phone off and on again can also help to delete temporary files to make room in your storage memory.
SOURCE: My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
SOURCE: htc's external storage card is not recognizing on my pc
Is the card working when you connect it to the desktop/laptop?
SOURCE: After doing a hard reset on my HTC TyTN 11 it just
TyTN II not charging. Will not turn on whilst on DC Car charger, or on USB cable charge. Orange light not coming on. But, flashing geen light each 3 seconds.
This unit is 3.5 years old. Maybe battery is DEAD.
(1) If battery removed, will data, contacts, sms etc be lost?
(2) Any method to check battery is dead?
(3) If unit not start with a brand new battery, how to copy data?
Hi @fmarcoux260496. I have some troubleshooting steps for you that may get HTC Sync working again!
On your PC, go to Control Panel and click "Add and Remove programs" in Windows 7 and Windows Vista or "Programs and Features" in Windows XP. Double click HTC Sync and choose "Repair."
If Repair does not work and you still get the error, reinstall HTC Sync. To do this, click on "HTC Sync" and then click "Change" or "Change/Remove" and follow the on-screen instructions. Do this for "HTC BMP USB Driver," "HTC Driver Installer" and "Adobe Air" as well. Once that's done, go to http://www.htc.com/ca/support/amaze4g-videotron/downloads/ and download and install HTC Sync. It is under the heading, "HTC SYNC 3.0.5579 FOR HTC AMAZETM 4G ' 15.12.2011". Complete instructions can be found by clicking "More." This will also install the newest HTC drivers and the newest compatible version of Adobe Air.
After you've finished installing HTC Sync, connect your phone to your PC via USB. Select "HTC Sync" from the "Connect to PC" pop up on your phone, and the phone will search for and open HTC Sync!
If you're still seeing the error message, disconnect your phone and perform a soft reset, and then re-connect the phone to your computer. To do a soft reset, just turn the phone off and remove the battery for one minute, then re-insert it and turn the phone back on.
If you still experience problems, I recommend you contact my teammates in Customer Support. You can find their contact information at http://htc.com/support
Please check in and let us know how that helped!
