I have a kenmore upright freezer. The Inside temp of the freezer stays at about 55 degrees all the time, Even at the coldest setting. I had I ice at the bottom of the freezer and the temp stayed right at 55. I unpluged the freezer for 48 hours to let it thaw out. I turned it back on and again it dropped to 55 degrees but when I touch the bottom of the inside of the freezer its Ice cold. Cold to the point your hand sticks to it. My question is Why is the bottom cold and the rest of the freezer warm. Is there a circulating fan that is not opperating or do I have a bigger problem?
Any suggestions will be helpful.
This Guy nailed my problem. I took the inside back cover off and my fan was froze up. I took the fan out and loosened up the shaft put it back in and it turned right on. In a matter of 30 min the top temp of the freezer was at 38 degrees. Thanks man.
