Question about V, Inc. Dump Trailer Pump 12v Dc Double Acting Hydraulic Pump
How do I prime the hydraulic pump om a dump trailer.
    New Friend:
  • 20 Answers
I've always just cycled a hydraulic system full open of the piston and then full closed. The air works it's way out on its own.
Posted on Feb 17, 2013
6ya staff
SOURCE:
Pump won't fill with hydraulic oil
have to bleed air out of pump just like primeing it
Apr 22, 2014 | Cub Cadet Garden
The dump box goes up, but then comes down before we can spread our load.
I'm guessing this is a power up, gravity down system (pump runs to raise the trailer, and doesn't when it's let down). Should be a check valve on the pressure side, and a solenoidal actuated return valve on the fluid dump side that lets fluid back into the tank from the hydraulic cylinder. It could be a bad check valve, or a bad seat in the return valve.
Aug 18, 2013 | Plumbing
Hydraulics stuck won't let trailer back come down
Bleed the hoses.Too much air in the system and low on hydrolic fluid.
Dec 20, 2012 | Hydraulic Dump Trailer Blueprints
Have a 7x14 bray dump trailer dumps 3/4's then runs out of fluid. to fully dump i have to add fluid then as the box lowers down it pushes the extra fluid on to the ground?
When the dumping piston lowers, there should be fluid being taken into the other side of the piston from the return hose. The fluid level in the reservoir should not change. Has the hose routing been changed from original design?
Gary
Jul 26, 2011 | V, Inc. Dump Trailer Pump 12v Dc Double...
Which fuse governs the dump hydraulic pump for the dump body?
This system is not provided by Ford, so look for heavy wires at the pump, and trace those back to battery power.
Fuses will most likely not be in the fuse panel.
May 22, 2010 | 2004 Ford F350
Ford 4000 hydraulic problems
First, make sure there is plenty of hydraulic oil in the reservoir
2nd, no leaks that are dumping the pressure
3rd, no blockage in tubes, located inside pump housing.
4th, make sure operating handle is engaging
try these and if nothing works let me know.
Jan 23, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
What is the torque on the pump bolts and how do i prime the pump
mounting bolts 70 ftlbs as far as primeing use some white lube on the gears it will catch its prime
Nov 17, 2009 | RTO Allis Chalmers 7000 Tractor Hydraulic...
1994 s-10 2.2l Filling with fuel
you have one or more injectors dumping very common with the 2.2
May 08, 2009 | 1994 Chevrolet S-10
DUMP TRUCK PROBLEMS
dump truck only dumping halfway. any suggestions
Mar 21, 2009 | Plumbing
Priming problem
Make sure you try to prime right when the machine is turned on, so that there is no boiler pressure making it more difficult to prime.
Johnny C
Sales & Service
www.CeriniCoffee.com
Oct 21, 2007 | Starbucks Saeco Italia Digital Barista...
V, Inc. Dump Trailer Pump 12v Dc Double Acting Hydraulic Pump Logo
296 people viewed this question
Top V, Inc. Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a V, Inc. Plumbing Expert? Answer questions, earn points and help others
