A Belkin Mini Wireless Optical Mouse frees you from the restriction imposed by the limit of the wire that your mouse uses to connect to your computer. The Belkin model works up to three feet away from the receiver and operates on a 27 MHz frequency. It's smaller than a regular mouse, making it easy to add it to a laptop case or desk drawer without losing much space in the process. Before you can use the Belkin Mini Wireless Optical mouse, you must install it. The receiver and the mouse should sync automatically; if they don't, you must perform the sync manually.
Press the bottom release tab on the top cover of the mouse. Insert the batteries included in the package and replace the cover.
Turn on your computer. Plug the Belkin USB receiver into a USB port on your computer. The drivers will install automatically.
Press the sync button on top of the USB receiver and then press the sync button on the bottom of the mouse to connect the two devices.
Warning
- close Before you can install the Belkin mouse, remove drivers for other wireless mouse types on your computer.
