I couldnt stop a print run and had requested too many copies as in 500 too many! this was at work and so i just left the printer tray empty but as soon as i put paper in again tomorrow i kno the print run will resume. how do i stop it please!
Hi Yvonne,
Try the steps below
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
(If you are using Windows Vista/Win 7, You need to click on START button and under search program and files - Enter the Services.msc and click the same program from Program list that appear )
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Regards,
Sean
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
SOURCE: False Paper Jam Error
Make sure the paper tray guides are set against the paper more likely to be the back guide not pushing the paper to the front of the tray. If you have the guides set correctly then place one sheet of paper in the tray and blot some methylated spirits on the leading edge along the page width and close the tray and try printing something.
You will have a jam repeat process 3 or 4 times then open tray and remove paper. Where you soaked the spirits into the paper there should be a grubby mark where the feed roller has rubbed and cleaned. Wipe the tray dry and put fresh paper in then hopefully you will now be able to print. If you cannot then the likely thing is that the paper feed pickup spindle is broken and will need replacing.
Hope this helps you and please rate me
Thanks J
SOURCE: prints fine then if printer is left for 10 - 20
for this problem you have to disable the sleep mode on printer
On the control panel,
Configure device menu ->
Resets submenu ->
SLEEP MODE to OFF.
this is better that altering the SLEEP DELAY under the System Setup submenu
Testimonial: "The printer I had didn't have a screen but I have know found the problem, and it's not worth fixing, I left possitive feedback for your time and help"
SOURCE: I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
