I m trying from since 2mounth but i cant do it
SOURCE: connecting and recording camera with s video output on 1221 tx
Your laptop has Tv Tuner card and if it takes TV input via cable , you get a S-Video / DVD cable to regular cable converter and use the laptop as a video recorder - if you are in US , any Radio Shack will be able to help you with the cables
The cam setup you're trying in your surgery is similar to the type I often setup in Dental operatories for there intra-oral cameras.
You need an tuner, if your external has S-Video port, you can simply plug into it and use windows media center or the cards software(if it came seperate) to record from the s-video feed.
Then you can hook the S-Video output from the laptop to the TV monitor in question and run the laptop in mirrored mode to show the same image on both screens.
Hope this helps,
Chris
