Juki MO-644D Mechanical Sewing Machine Logo
Posted on Feb 11, 2009
Threading juki DDL-227 machine
I bought a used Juki DDL-227 and am not sure how to thread it- mostly the first step. On top of the machine is a post holding a wheel. When I put the thread in that wheel it always comes out. need help. Thank you
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 23, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
2841
Points
25
How to thread a juki cp 180
I am surprised that I couldn't find threading directions in the manuals that I found. It appears to me that you can thread it the same way that you would thread a Juki DDL 555 or DDL 8700. Manuals on Line have several manuals but I couldn't find threading directions in them. Weird. Most sewing machines thread similarly whether they are home or industrial machines. Once in a while there will be an odd one. Sergers, etc are another matter but sewing machines are generally alike in their threading.
1helpful
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
I have a Juki DDL 227. Top thread keeps breaking instantly
Well, you've not checked "Everything" but you have checked the common things.
Do you have any idea of where it is actually breaking? Re-thread your machine and see if you can determine exactly where the break occurs.
Sometimes a damaged needle throat plate will break threads... as will a burr on the hook in the bobbin area. Also if there is a burr or rough spot on the thread spool it will sometimes catch and cause breakage.
Good luck
2answers
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
Hello, I have a juki DDL 5550, runs great, But the tension is off. Top thread bunches up on bottom side of fabric ( bobbin thread looks ok)\r\nThanks,S
Soulds like your not geting the top thread all the way in the tension disk. Make sure you have the presser foot up when you thread the machine. also after you get it treaded check to make sure you have tension, with the presser foot up you should have not tension and with it down it should be very hard to pull.
hope this helps
1helpful
2answers
I just got a used juki ddl-5550-6 sewing machine. There is no owner's manual. I think I have the machine threaded right. When I put the pressure foot down to start sewing, it pulls the thread down into the...
PLEASE CHECK FIREST TIMMING BETWEEN NEEDLE AND HOOK
OR GO TO WWW.JUKI.COM U WILL FOUND USER GUID ALL LOCKSTICH MACHINE SAME ADJUSTMENT WITH DDL SERIES
BEST REGARDS
2answers
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
