Recently changed heating element. When put back together their was a squealing, which would come and go. When I tried to start the last time there appeared to be a momentary grinding sound the squeal and then stopped working. When I try to restart there is a lound hum when start button depressed, but wont come on. thoughts?
SOURCE: kenmore 80 series dryer
humming noise usually means a bad motor. how much did you disconnect when changing element?
SOURCE: Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
SOURCE: Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its very easy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
