Smeg oven not working. only clock and thermostat light working
My smeg oven will not heat up, the grill, fan, element, internal light are dead as a dodo. However, the clock and thermostat light are working. Can anyone help me. the oven was making a funny smell for some time beforehand and twice the oven cut out in the middle of cooking (it would start again if left for a little while and the temp control etc switched off and then back on again
Re: smeg oven not working. only clock and thermostat...
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch.
If it is buckled, warped or has a blow hole in it, then it's faulty.
If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
