Free download soft ware for IBM thinkpad G40 2384 audio drives
You can get the driver from the computer manufacturer's website. If you want all drivers covered and updated, then you can install an automatic driver updater like RadarSync. You don't have to go to different websites to find the different drivers because the software will do all the work for you.
I hope this helps!
David
SOURCE: Sound problem
Go to control panel,and check device manager to see if you have any problems. If not, click on Hardware and Sound, then on Sound, and see if somehow your laptop speakers have been turned off. Reconfigure them anyway, and test the sound there. If that doesn't fix it, go to IBM and reinstall Realtec. Sometimes it gets corrupted, and sometimes it takes more than one installation to get it fixed. Let me know if you have any problems.
SOURCE: IBM R60 thinkpad Audio prob
Try to install all the new drivers from this site
http://www-307.ibm.com/pc/support/site.wss/MIGR-64283.html
i think it will solve this problem. Dont forget to install chipset drivers graphics drivers etc..
Thanks
mohan
SOURCE: video and audio drivers for IBM thinkpad 1161
Go to the IBM WEB site www.ibm.com and click on Support and Downloads
SOURCE: IBM THINKPAD AUDIO DRIVER
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
Note:
If the card has a exclamation mark over a yellow background, then this
is an indication that the card is experiencing a problem. Go to Driver
download step 5.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
If you double-click the previously mentioned system tray icon, the
configuration utility of the wireless card will appear. This utility
will be able to show the status of the wireless card, showing what
channel the card is using and what signal strength is being received.
It may be difficult to maintain a connection if signal strength is low
due to either interference or distance. For example, interference can
be caused by 2.4GHz cordless phones, other Access Points in the area,
and physical structures such as load bearing walls or metal partitions.
Note:
The utility can be used to configure the wireless card settings, but if
using Windows XP Zero Configuration or Access Connections, you will
need to use those programs to actually configure the wireless card as
they will overwrite the setting of the utility.
