This problems are a very tipical of the coded pixels on the LCD screen panel passes through the board that call the T-CON decoder board to causing this problems.Vertical colors lines display on the LCD screen panel happen by itself.Yes.The T-CON decodering board it is dying and shorting out.This T-CON decodering board sit in the middle at the botton of the LCD screen panel.Replacing this T-CON decodering board will solved this problems,if does not the LCD screen panel itself it is shorting out,than the tv it is not worth fixing,because changing the whole LCD screen panel itself it is not practical and the cost will be the same as a new tv itself.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
the serial is located on the back of the tv in the lower left corner. Or u can press the green button on the remote after u press the menu button, u will get the option to display the serial on the screen
You can download/print the PDF owner's manual from the LG website. Click on the SUPPORT tab and you'll find links to several documents that you can download.
