HP Compaq Evo n610c Notebook Logo
Posted on Feb 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
Anonymous
Level 3:
  • HP Master 32,281 Answers
  • Posted on Feb 15, 2013
Anonymous
HP Master
Level 3:
Answers
32281
Questions
Helped
7905940
Points
102259
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
3 Related Answers
davepcrepair
David Grassel
  • 75 Answers
  • Posted on Apr 12, 2009
SOURCE: Laptop will ot boot
do you have the cd? if so do what its saying on the screen there if you do not have a cd and it didnt come with one then you will need to access the hidden partition of your harddrive that stores the operating system files and to do that veries from each computer if you have a manual for it then it will tell you how most of the time its a key you press when it first turns on such as F10 or F 12 it will probly tell you when you first turn it on what to press but if not look it up in the owners manul
frankzjm
Frank Zhang
  • 191 Answers
  • Posted on May 11, 2009
SOURCE: file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
I mean your documents are very important so do not install xp setup before the data backup, you can use a USB adapter connect to a normall PC to do so. and then tell you how do install xp CD.
1) load files -->press F8 -->confirm install new xp --> detect a disk
--> choose c: disk (this step you can change disk pertition)-->format disk c: --> copy files keep in touch ....to finish.
hope it help you to deal well
Anonymous
  • 78 Answers
  • Posted on Jul 20, 2010
SOURCE: Windows could not start becuase the following file
The answer is in the question Mary.
More specifically the steps here might help:
http://support.microsoft.com/kb/319136
1helpful
Starts up goes to start windows then goes off and comes back to start again
It is more than likely the hard drive, or the window files are corrupted, if you have a backup recovery disc try it now, no change! have the hardware tested.
The problem i'm having is starting it up ,it will power but not start and then shuts off
The WIN.INI file is probraly corrupted.
Star the pc and hit F8 go into safe mode and search for your WIN.INI file it should be inside the windows folder base
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
3helpful
2answers
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
2answers
Problem loading os on compaq evo n610c
Make sure you start by deleting the old partition, and formatting C:. If it still locks up after that, then your hard drive is bad.
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
2answers
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
2answers
Compaq Evo N610c HD error message
You need a disk. Borrow the same O/s disk from some IT person Or contact Microsoft / or HP authorised dealer they will be provide the disk.
Use repair option, (Else You will loose the data)
If you donot need data format and reinstall the Operating system.
Regards
Rafique
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
