My washing machine is flashing an F02 error code. The washing is in it and looks as though it has been spun but the door is still locked and I can't open it. I live in a rental property and there is no manual for the machine. Help gratefully received. Thanks. Helen
Hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Thanks for this tip, really easy to do once you know where to look.
Tip: use a plastic bag to collect the water. You might have to fill and empty a few times before you are clear, but don't remove the plug all the way, let it out just enough to let the water spill into the bag laying on the floor.
Thanks for this response, I had the same codes and did as instructed (boy it smelt and there was lots of water !!), result as it was rammed with fluff, about to start it again so should be sorted !! Thanks again
