Hey.
I know I might be a couple of years late, but I found an extremely easy way of resetting the password on ProBook 6570b. While the PC is booting up, press ESC. Then F12 for Network boot. It will glitch and bring you back to the previous screen. Then press F10 and it will get you straight to BIOS settings from where you can change anything you like and even reset the password quite easily.
Hyjacker moneef
there is no bios PW reset jumpers in laptops (toshsiba execpted)
the maker HP flat refuses to help, (this topic)
means they tell you to buy a new motherboard (wow)
so that leaves what?,
HACKING.
so google it.
some of these laptops have backdoor PW (bios)
and if you hit enter 3 times it shows a hinted PW code. if yes,, then.
then google this.
probook 6570b backdoor Password, reset
or pay these guys
https://bios-fix.com/index.php
and
https://bios-fix.com/index.php?forums/hp-bios-password-remove.237/
SOURCE: hp probook 4310s bios password
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some tutorials. For example the tutorials:
Reset HP / Dell BIOS Password.
Top 3 methods to crack bios password!
3. Use the bios password recovery tool , but that is not free!
So I would suggest you the 1st method. Hope it helps.
SOURCE: How do you reset are
Welcome to FixYa!
Are you the one who set up the BIOS password? If not, unfortunately, there's no way for us to retrieved the password. The only way you can reset the password to default settings is to reseat the CMOS battery on the motherboard, its a circular thing that looks like a battery of a watch,sometimes a pin hold it, just detached it then wait for at least 30 minutes then connect it back again,
Note: Before you reseat the CMOS battery,make sure that everything is unplugged on the computer, like AC adapter,battery and all external devices...
Hope this will help...Thank you for using Fixya...
SOURCE: i want to reset my
Dear tonidamayor
Turn off your system. open the cabinet there you can see a button cell(cmos battery)
Remove it and hold out for more than 30 seconds. then replace it again to same position. and switch on your PC.
Cheers
SOURCE: the hp probook 4510s laptop
IF you set the BIOS password then when you power on the notebook it you would be ask you every tiem BIOS password and not if you want to remove bios password then go in BIOS utility then remove bios password
