I'm wanting to connect this Samsung TV to a Vizio soundbar as well as a Panasonic Blu Ray player. However, I'm not sure what particular cables to buy. I need to know if this particular TV model is ARC compatible before I buy two HDMI cable that I won't be able to use.
SOURCE: I have a Samsung 46
This happens on our samsung too with some dvd's.
It is not the tv's fault (in my case) but have to turn the volume button on the dvd remote up full first then adjust from the tv remote as required.
SOURCE: i have a samsung tv and samsung blu ray i have my
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
SOURCE: i connected a samsung home
You need to connect the "Audio/Digital Audio Out" of the TV or Cable box to the "Audio Input" of your home theater receiver.
SOURCE: I pluged in a blu
Hi, please what you saw,i would like you to put more light into what you said that display son the screen.
"seathrew window "...
Thanks..
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
