Hey i have already dowloaded all types of go sms for my phone and i still cant send messages..SMS .. can you figure out the problem and give solutions??
send me email at [email protected]
SOURCE: how to activate & send mms in samsung s8000 mobile
you need to configure the mms settings from your internet menu... but you need the right configuration from your network provider to the settings..
to give you an idea, here's how you may do it..
from your phone, press menu
select internet
select browser profiles to lead you to internet profile settings..
from your settings, press create.
then create the mms profile your network preferred.
once created, press save and exit the settings for internet profiles..
to make the mms profiles be the default settings for your mms, do thes steps...
select settings
select phone applications
select messages
select multimedia
from multimedia menu, select profiles
assign the mms profiles you created for your multimedia.
press save and exit the setup...
now to check if it's working, try sending a multimedia message to your own number to check if your phone can send and receive mms. once you successfully send it and received it, it means that your phone mms is already set and working...
take care..
SOURCE: Can't send SMS in roaming
hi there, You can try to powercycle your phone,if still doesnt work you and this is the first time, you may need to contact your network carrier. good luck!
SOURCE: Samsung Tocco Lite MMS message sending problem
Steps to correct the MMS delivery time
1. Select Menu
2. Select Messages
3. Select Message settings
4. Select Picture Message
5. Select Sending options
6. Select Delivery
7. Select Immediately
8. Save the settings and retest sending MMS.
SOURCE: I cannot send and receive
If you can make calls, then it's issue with the service provider. They probably didn't activate your txt features for your account. Call Smart Network to activate. If you can't make calls, then the issue is likely with the SIM card. You need a replacement. Either way, call Smart Network and they will provide you with a new card
SOURCE: cant send mms on my
You need MMS settings along with active GPRS connection. Call your service provider's helpline and ask them to send MMS and GPRS settings to your phone. Once you receive the settings, install them and reset the phone. Hope this helps you!
