This works with devices having physical home button
1. Press the power button and the home button together
for a while, long enough until the screen appears with Android bot and a
progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
Note: I Use My Tablet SUNBERRY, and reset my Tablet
Turn Off your Tablet and then
Press Power + Volume Down (Press up Factory menu Show)
If you use Android 2.2 (Froyo)
Press Wipe data / Factory Reset -> Yes, Delete ALL user data -> if Finish press Reboot Now
If you want more other andoroid OS and other tablet visit my Blog
you can see how to Reset android with video
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
This solution works for
most tablets.
Power off the tablet
Tap Power, then press
and hold Power + Vol Down until you get a menu, then release
• Look for a Recovery or Factory Reset option, and select it.*PLEASE NOTE THIS WILL ERASE ALL DATA, INCLUDING THE PASSWORD*
