It's really bothering me. I keep trying to play online games and it disconects me all the time in the most important parts. Im furious
Step 1:
There are many possibilities of what the issue is. You need to first figure out your setup.
Some questions to ask are:Step 2:
First thing is to check your wireless connection.
If there are a lot of computers using the wireless at once doing activities such as online games you could expect disconnects to be possible.
Try to be the only one using the wireless internet and see if you have the same issue. If this works, then your internet can't handle all of the computers using it all at once.Step 3:
The next thing is to check your internet connection in general. Try connecting the computer directly into the router or whatever your internet is coming from and see if you have the same issues. If it works then there is something wrong with your wireless internet.Step 4:
The next thing is to check your game. If this issue only happens with a particular game and not the others then there is something wrong with your game. Depending on what game you are playing, the issue may be more than just your internet.Step 5:
If you still having the same problem after doing this, you need to look at your computer. If your computer is old (maybe 3+ years) it's possible that your wireless nic card may be too old to go fast enough for the online games. I assume you are talking about playing big pc games vs. playing card games online.
Possible options:
1. Clean out your computer. Empty recycle bin, delete old files, run disk clean up or use ccleaner (download at www.cnet.com), defrag your computer, and etc.
2. Get a new wireless nic card. If you get a new nic card, I'd prefer getting one that uses N wireless since it's currently the fastest. I'd suggest using this suggest if your computer is relatively old (around 3 years). Keep in mind that I talking about how old the computer is and not how long you have had the computer.
3. Save up for a new computer.
Try a USB wireless device. If it works, then your internal wireless adapter is bad and can be replaced.
See Anthony's solution #5 and then #1. There is a need to keep the laptop COOL, CLEAN and then you mention that it shuts off at the good parts, just may be too much game for your laptop. Possibly there may be a need for additional memory, It is possible to also need to purchase a faster internet service....
Good Luck to ya
SOURCE: Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
SOURCE: Wireless Connection Difficulties
sounds like your wireless card in your laptop needs either a replacement, or new drivers.
www.sony.com
SOURCE: staying connected to the internet
if you are up to it you might wont to swith to verizon Fios they have same things like chart that includes internet, tv, and phone. There modems are easy to set up all you have to do on there modem is enter the ip adress enter the defalt user name and password and change it to one you can remember and you would be online. One other thing most of there routers have built in wirless network asses which is protected by a WEP password which is located on the botom of the router.
To check if you qualify go to www.verizon.com and lock for there to enternet choces you wold need to enter you home phone # or adress to see if it is avaliabe.
i hope this would help.
SOURCE: wireless internet connection
Hi there I would tell you why:
1) your DSL speed band only 1.5M and the upload could be lower then 256K speed. that is not avalible to get good condition for more laptop wireless online at same time
2) other thing, your laptop wieless online in your router situation that depends on the laptop wireless card type, high level (faster)card will get more speed band and aganst other laptop.
so you could not setting any more to get improved.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
SOURCE: No internet connection
if you are worried about the icons that are sown in the tray system ( lower right in the task bar ) those are showing the other connections that are not working at the time ...for example the LAN cable conection ...and the blue tooth ..those will appear not connected if you have no cable on the Lan card or blue tooth device connection ...even if you are connected via wireless those will appear unless you choose to unchecked the show in tray ...
if you are asking about the connection you have made wireless and it doesnt work ...you probably have a driver problem ..just reinstall the driver for the wireless card if you know that the connection should work ...if you have acces on the net wireless those icons that are x-ed on the right on the task bar are for the other connection methods ..so do not worry ..
Testimonial: "I hope it will help and thanks a lot..."
