SOURCE: Keurig b40 elite turns on, then off after a few
I had this problem and it got worse. I had to return the coffee maker to Keurig. They sent a refurbished one, which also had to be sent back. I am getting irritated with the poor quality.
SOURCE: My Keurig Elite B40 will only brew one cup of
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
SOURCE: I turn the power on
Hi, well what happens usually is the little thermistor goes open circuit, and this then stops the heating element. It's part of the thermostat controller.
Sometimes it is the thermal fuse, again inside, this is a device that if overheated it goes open circuit and cut off power to the element.
If one is repair inclined then replacement of these things are not too difficult, however, one needs to be able to order spare parts, and to do this one needs the all important parts numbers, usually only available from a service manual, or a repairer.
so unfortunately like with a few things that i see in my shop these days it is most likely an uneconomic repair?
The cheapest and best way to sort this out, is to get the unit looked at by a professional, however before just giving the go-ahead to repair it, please ask for a "Quote", this way at least you will know what's what.
SOURCE: Water runs continuously and doesn't
Hi, According to you the water is not heating of your coffee maker. There is some problem with the heater system of coffee maker. May be the fuse is dead or the connection or the wiring cut out. check ant repair it. May the brewer need cleaning. Periodic descaling of the machine is recommended for your brewer. More frequent descaling may be necessary depending on the hardness of the water. See the manual or contact with nearest service center.
SOURCE: My coffee maker is only 6 months old. All of the
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
