Hello here is the homepage:
http://www.asrock.com/mb/Intel/775i65G/?cat=Manual
A repair manual can only be found at a asrock dealer.
They will probably not give that to you.
If the mainboard is dead, the solution is to buy a new.
It will cost to much to let be repaired.
Good luck
SOURCE: it doesn't turn on
Try to reset the CMOS, remove the Battery on your motherboard, its like a silver flat coin, or if you can locate the RESET Jumper, just move the jumper to short. Then try booting-up your system again.
I hope this procedure will help you.
-mrsolution
SOURCE: The MotherBord ASRock 775i65g
hi there,
download from the link below
http://www.asrock.com/mb/download.asp?Model=775i65G or download from http://driverscollection.com/?file_id=35254
Good Luck!
neo
SOURCE: original driver of asrock 775i65G motherboard was lost
pls see the link for drivers and Pls rate me FIXYA for help
http://www.asrock.com/mb/download.asp?Model=775I65G&s=775
SOURCE: I need drivers for Asrock 775i65G, im runnig vista ultimate ?
You wont find them at asrock.com because it is not certified for vista.
you can contact them at
http://www.asrock.com/support/TSD.asp
Mark
SOURCE: Reset A Bios of Asrock mother board
go to the following site
http://www.asrock.com/mb/manual.asp?Model=K7S41GX&s=462
download the user manual(not quick installation guide) and check page no 7 or content 1.3 to get the jumper pins to reset the motherboard.
just short those pins and the cmos settings will be gone.
another simple method is just remove the battery and wait for 5 min and again plugin the battery.
thats it you motherboard is resetted to factory settings.
