I have a Motorola t305 speaker for car it won't let me pair it i put in pass code oooo it says it is right code but make sure device is ready and it is solid blue just like it says but still won't pair I have another one Indy van and don't have any problems and also I made sure I turn that one off just in case
SOURCE: how to configure or pair my motorola T305 car
First step:From your nokia e63,scroll to bluetooth goto paired device and click on add device after that,then pick up your bluetooth and press down the power button make sure you did not remove your hand from the button until it displays on your phone.
Second step:After your phone has found the device,click on the device from your phone and you will be ask to type a password which the password is 0000.enjoy
SOURCE: when I try to pair
Just Go through this process again,and please let me know >
How do I bond and pair this device with a phone?
The T215 connects wireless to your phone and allows hands free operation while driving. If you would like to pair this device, follow the steps listed below.
Initial Pair and Connect
Turn off any Bluetooth devices previously paired with your speakerphone..
Turn on the Bluetooth feature of your phone. (You may need to contact the manual or manufacturer of your phone.)
Slide the Power Switch of the T215 to the On Position. The Bluetooth and Battery indicator lights alternately flash to indicate the speakerphone is in discoverable mode.
Set your phone to search for Bluetooth devices. (You may need to contact the manual or manufacturer of your phone.)
Select Motorola T215 from the search results on your phone.
Select OK or Yes to pair your speakerphone with your phone.
Note: When prompted for the passkey, enter 0000.
Note: The Bluetooth indicator light changes to solid blue for 1 minute to indicate successful pairing and connection.
Note: For daily use, make sure your speakerphone is turned on, and your phone's Bluetooth feature is on. Your speakerphone and phone will connect automatically.
Get back tome when you are through.
SOURCE: passkey for Motorola T305 to pair with Palm Treo
just kept trying with 1111 and finally it worked.
