TEC B-SX4 network card respond to ping but wont print ??? JOB stac in the spooler..... same with an other pc...
SOURCE: Hi, I can print to a TEC B-SX4 from a windows 2000
this is due to continuous polling by the driver.
You must disable the bidirectional communication in the tools tag ,driver options, network parameters.
SOURCE: Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
SOURCE: TEC SX4 Label printer received
How do you communicate with the printer?
If by serial check the speed parity etc frma the parameter menu
Else check that the character selecter for esc sequence is correctly programed els choose Auto.
TO en ter parameter settings
Switch on with feed and puase key pressed. When (1) diag V XX displayed press feed
(2) parameter is displayed.
With the pause button you can navigate in the menu and feed and restart allows you to change the value.
Else do a parameter clear to put everythig to factory defaults
SOURCE: Toshiba TEC B-SX4 paper jam
Size problem or type of material problem or recalibrate the sensors.
All in the owner's manaul
SOURCE: bonjour pouvez vous me dire
Pour installer en r?seau deux solutions.
1 Installer la carte r?seaux et param?trer l'adresse ip, l'adresse passerelle et le masque de sous r?seau.
Soit sur le paneau ou en utilisant les commandes ci-dessous en modifiant les valeurs:
{IP;2,192,168,001,201'} adresse ip
{IP;3,000,000,000,000'} passerelle
{IP;4,255,255,255,000'} masque de sous r?seau
{IS;1,09100'} activation du port telnet en 9100
ou
brancher un boitier axis ou netgear sur le port parallele
