Symphonic WF20D4 TV Logo
A
Anonymous Posted on Feb 12, 2013
Does my symphonic wf20d4 have a digital tuner
2 Related Answers
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Aug 10, 2009
SOURCE: vcr
Yes you may hook that up to the coaxle end of this unit or the RCA scart connection on the back.
The coaxle end you would need to be on channel 3 or 4 make sure you verify witch channel you vcr is under. Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • Posted on Jan 10, 2010
SOURCE: Unable to program my Time Warner Cable remote to Symphonic TV
the instructions are on the back of the remote. if lost. you have to:
1) Turn tv on ( i would suggest turning it off then on)
2) Press the Device you want to sync (tv)
3) Press and hold the setup button it will blink once...let it blink twice before you go to the next step.
4) press 9-9-1
5) press the power key on the remote
6) press the channel up (CH +) button repeatedly until the device (tv) turns off.
7) when it cuts off immedieately press the setup button.
I need remote control codes for my symphonic model WF24T5 to use my dishnet remote please
Use the remote dishnet to automatically detect your code for the tv. Most of the time the procedure is on the remote.
I NEED A REMOTE CONTROLLER FOR MY SYNPHONIC TV
Hello
Just buy one "ATLAS METROCAST -OCAP 5 DEVICE" universal remote control. Symphonic TV is listed with its codes. Codes are:
0180, 0171, 1944
Setup proceedings can be had with its catelogue. OK
How can I set up my stereo speakers to my tv? I have a symphonic WF20D4, flat screen with built in cd/dvd player. I'd like to be able to set up the speakers from my stereo to this tv but can't figure it...
You are correct if your TV doesn't have audio output you can buy an adapter at radioshack or online probably 1/8 to RCA like this one here
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
1helpful
Vcr
5helpful
I have a WF20D4 TV and a comcast universal remote. I can not find the code that turns my tv on and controls volume for my comcast remote. I lost the TV remote.
0180, 0171, 0000 if your remote has a GREY ok/select button on it,
20675, 20821, 20000, 20593, 21593 if your remote has a RED ok/select button on it
2helpful
4) press 9-9-1
Symphonic television has no sound
It's probably either a defective speaker, or something defective in the Audio Amplifier stages. If the set has an audio output jack, you could try plugging into a small stereo and see if that gets you by.
Hope that helps...
Geno
Using v -smile on symphonic tv
go below Ch2, you may see L2 and L1 before it goes to ch132 or highest tuner channel.
Remote code
Codes for symphonic are one of the follows: 1026,1033,1038,1046,1155,1189
Hope this helps!
Most universal remotes also have a search mode. They work like this. Most want the TV turned off. Than press the button (TV) than press & hold the set button till the led comes on. Point the remote at the TV than press the volume + to increase. This will take you through the codes one digit at a time. Each time you press the + the remote moves up to the next code. This may take several minutest. Once the TV turns on press the set button again & the led will go out. That's it.
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
