SOURCE: record problem
There are two things 1.there is a push switch under the cassette holder may be brocken 2.cassette holder is bad.put a cassette and press on cassette holder then try this way you can make sure which part is bad.
SOURCE: I have JVC Compact Videomovie GR-AX5. Cannot see
Most likely, broken ribbon cable from viewfinder to main board is the cause of the problem.
SOURCE: I have JVC compact VHS,videomovie GR-AX35. My
This is due to a fault in the servo system / control system. If there is a error in the loading then due to the loading being off mode the controller can trip off power.
Also check the power section and the capstan/drum motor section.
Check if loading is back to parking mode. If not unwind and allow the loading to park and see if the power latches. if so check the loading motor drive .
