I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
I just finished getting a P1006 working on both Xp and Vista. The primary part that is missing is that in both XP and Vista, the default OS install does not include LPR print services! Once I installed that the remainder worked fine.
In both OS's, you go through control panel to add/remove programs or Programs & features. In the left pane is a link to change windos features. Middle of the list is a check item for print capabilities. Turn on ALL options.
In the install I did I'm actually running RAW instead of LPR, but this was needed to get either working.
Also, if you are running through LPR with a queue, you want to check off enable byte counting.
I've been trying to get it to work with a P1006 Printer, and it doesn't look good. If you're able to get it to work, please let me know.
i have the same problem with DL-301U on P1006 printer, it doesn't work. helpppppppp me pleaseeee.
Found D-Link's list of compatible printers for DP-301U - ftp://ftp.dlink.it/products/DP/DP-301U/Compatibility_List/DP-301U%20Printer%20Compatibility%20List.pdf
