It wont let me manually adjust the voume on my microphone.. It auto sets it too low and when i am chatting online the other person says my voice gets lower and lower..
Im using WinXP Home.. I am using it with Yahoo Messenger.. For calls.. Each time I adjust the volume it resets itself to VERY low.
Thanks
Delete the registry files for the devices and then uninstall the driver from device manager and then uninstall the software.
That worked for me.
If you need additional help you can contact me on Skype. Username: Skatedawg.
I had same problem with Yahoo Messenger until I found an option to disable it (Auto mic volume). Go to Preferences -> Calling & Audio and check the "Do not modify my mixer settigs (Advanced)".
That should fix it
Using
a microphone with computer
To use any microphone with your
computer you will need to enable it in control panel. The following
instructions are for Windows XP but are broadly similar for Vista
and Win7
Click START, CONTROL PANEL, SOUNDS
& AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices
Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure
that there is not a check-mark in the MUTE box against microphone in the list
of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't
checked before closing the window.
Now click the VOLUME button in the
SOUND RECORDING BOX. Here SELECT microphone as an input source for recording
(as opposed to un-checking mute in the playback controls).
NOTE if your microphone
is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES
on the tool-bar and place a check against microphone in the list
entitled 'show the following volume controls' and then click OK. Same
applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume
as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust
slider to suit.
You might put a check mark in the box
to show the volume control on the Task Bar so you can go straight to it to make
adjustments in the future.
See Adjust volume below
computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista
and Win7
& AUDIO DEVICES
Click VOICE
Properties window locate SOUND PLAYBACK box. Click VOLUME button.
Make sure that there is not a check-mark in the MUTE box against
microphone in the list of devices and the volume slider is at the top of
the scale.
Ensure the MUTE ALL box
isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for
recording (as opposed to un-checking mute in the playback
controls).
NOTE if microphone is not listed in the
2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and
place a check against microphone in the list entitled
'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Have tried that. The mic volume is set to MAX there. But when I click on Control Panel>Speech and then on Adjust. The volume is set very low on the actual device. And its stuck there. I cant manually adjust it.
I think it tries to adjust it to optimal automatically... Problem is, it think the Optimal setting is much lower than it should be. Thanks
I have the same problem. It was working fine yesterday but now the microphone is too low and people cant hardly hear me. I am talking loud but it just sound normal to them.
Mic volume auto adjust down and people can hardly hear me
